Activity Forums Blackmagic Design Trouble exporting to tape via Blackmagic deck control
  • Trouble exporting to tape via Blackmagic deck control
    Posted by David Stack on June 23, 2011 at 8:25 pm
    In PP CS5, after playing around with various sequence and project settings at some point I’ve been able to export a couple of shows but not without a dropout here and there. Today, once I felt I had all my settings just right I can’t even get the deck control to record more than a couple of seconds, and when I did the audio was out of sync. I’ve resorted to a crash/record without deck control just to get the show playing. But I have to figure this out today for my deadlines. I have a show with closed captioning which will require deck control.
    I’m working with:
    MOBO: ASUS P6X58D-E
    Intel Hex Core i7 970
    RAM: 16GB
    Microsoft Win 7 Professional, 64bit
    GeForce GTX470
    System drive: Western Digital VelociRaptor, 10,000RPM
    DECKLINK HD EXTREME card
    SONY BETA SP DECK, PVW-2800
    PP CS5
    BTW, the show is playing out without any dropouts with my crash/record. My shows are in SD and my sequence settings are…
    David Stack replied 15 years, 3 months ago 2 Members · 3 Replies
  • David Stack
    June 24, 2011 at 1:42 pm
    UPDATE: I’m successfully playing out a sequence from another project with deck control, however every few minutes it STOPS. In a 30 minute show it stops randomly about 3 times. It’s frustrating and will be a problem when I’m encoding closed captioning to the tape as well if this keeps up. I haven’t seen any dropouts yet.
  • Pentti Kakkori
    June 25, 2011 at 6:07 pm
    Do you have Premiere Pro project Auto Save on?
    If you have, take it off before exporting to tape.
  • David Stack
    June 27, 2011 at 12:38 pm
    Thanks for the tip. I’ll give that a shot. Although if that were the issue wouldn’t it stop in increments of 10, 15, 20 or however many minutes I have set for autosave? These stops seem to be totally random.
