Activity › Forums › Adobe Premiere Pro › Trouble Exporting Project to Tape and DVD
Ce3am1 replied 19 years, 5 months ago 3 Members · 36 Replies
Vince Becquiot
April 5, 2007 at 10:58 pmWell, first thing that comes to mind is a trial version, but I’m guessing you are using a full version since ISO works ?
If Nero is installed (especially the Suite) it’s likely taking over the drives and conflicting with Premiere.
In fact Nero can even be an issue after it’s removed…What you may be able to do, if you want to keep Nero, is export as folder, and use Nero’s DVd video wizard to burn those to disc. I know people have reported issues with that, but I’ve done it in the past without problems. You can also export as an image and use a free application ( https://isorecorder.alexfeinman.com/isorecorder.htm) to burn the image to disc.
Vince
Christopher Szabo
April 5, 2007 at 11:01 pmHey vince. i lowered that average bitrate lik you said and it fixed my problem. now, i am still having issues though with exporting to tape and putting these videos on my iPod. i used a program called Pinnacle Mobile Media Convertor. It successfully converts all videos into mp4(iPod format) but when i try to convert the Adobe Premiere AVI exported files, they come out crappy on my iPod, as well as on playback on my computer. what can i do to solve THESE two porblems?
Vince Becquiot
April 5, 2007 at 11:21 pmThe only program that I use to convert files for an Ipod is Quicktime Pro. Most of the other converters I’ve seen either make the workflow tedious, or like you said make a crappy looking video. Of course, keep in mind that an ipod video viewed on a PC won’t look very good.
For the export to tape, I’m afraid that the best solution would be a system upgrade. There is a software called Video2DV (https://video2dv.com/). It will demand a lot less resources than Premiere and should provide a smooth playback of DV files (most files in fact) through firewire. The catch is that you’ll have to export the file to DV first, and then, it’s not really free either.
Cheers,
Vince
Ce3am1
April 6, 2007 at 12:58 amThank you Vince !
I understand , that your recomendation is – NERO to be remouved . I’ll doit ,Bug / last question may be :)/ if the problem is still actual , what have to be my next step ?!
My produkt is’n trial wersion..
I know about other ways /folder + burn with NERO/like many people said , byd I want my product to be 100% accurate.
Regards
CE3AM -
Vince Becquiot
April 6, 2007 at 2:05 amIf the problem is still there (and it shouldn’t be;), I would use the image method.
It is as accurate as a direct export, and in fact is better, since you can use the image to burn additional copies later. So, use the ISO export option. Then I believe, once ISORecorder is installed, it is a simple matter of dragging the file to the DVD drive (make sure you right click on the drive first and enable “recording” in the properties). There are other free image burners as well, alcohol 50% comes to mind.Cheers,
Vince
Ce3am1
April 7, 2007 at 11:30 pmHi!
Two days I work with my Titler… Everithing was OK. ..Bud today I’m not able to open it 🙁
I tied many timen…
About DVD buton – I deinstal NERO , no rezult . Covert to ISO file – byd ISO burner wasn’t able to burn DVD… I instal again NERO and bur DVD with NERO Burning Room – exlent quality 🙂 The problem is , that I can’t use Vision, Express, Recode../ NERO/ when I have ISO file for burn..
What is you gesing for Titler Vince ?!
CE3AM
