Activity Forums Apple Final Cut Pro Legacy Trouble exporting a keyed clip
  • Trouble exporting a keyed clip
    Posted by Dan Stubbs on September 14, 2007 at 10:27 am
    Good afternoon,
    I have created a clip which I have keyed. However when I export the clip as an avi I cannot ammend the clip I am just left with the talent against a blck back-ground – ie. I cannot put an image on top of the clip. I imagine there is a fairly simple solution to this but I can’t work out how to export the clip so I can manipulate it afterwards.
    Any advice?
    Tom Wolsky replied 19 years ago 2 Members · 3 Replies
  • Tom Wolsky
    September 14, 2007 at 11:35 am
    You have to export it using the Animation codec. Use QuickTime Conversion, set the codec to Animation and the colors to Millions+.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Dan Stubbs
    September 14, 2007 at 1:23 pm
    Thanks for the reply, unfortunately ive tried that and it still isnt working. Some have sugested you need to export it un-rendered but if I do that the green key re appears. Any ideas?
  • Tom Wolsky
    September 14, 2007 at 2:08 pm
    Sorry I missed a bit. You’re exporting as an AVI. You’re going to a PC? Is that right? I’m guessing here. In which case it’s not going to work. You’ll have to key on the PC.
    All the best,
    Tom
