Activity › Forums › Apple Final Cut Pro Legacy › Trouble apllying the astherisk method in the end roll text
  • Trouble apllying the astherisk method in the end roll text
    Posted by Thiago Lima on April 13, 2006 at 9:05 pm
    Hey,
    I try the astherisk method in two workstations and i have the same problem. When i aplly the the astherisk in the text that should be at the left of the screen (the astherisk is after the text on righ side) i have the error message out of range. When i aplly in the text on the other side no probvlem happens and the method works. Do you guys know what that should be?
    Thiago Lima replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
