Activity Forums Apple Final Cut Pro Legacy Trouble Adding Video Transition
  • Trouble Adding Video Transition
    Posted by Steve Cohen on April 7, 2009 at 10:51 pm
    I can not drop a transition into the timeline. I am currently dealing with an opening sequence that includes transitioning between two stills, I am trying to drop in a simple dissolve and it will only take to one side of the cut, and then I am unable to lengthen or shorten the duration. There is plenty of material on the A and B side of the cut for handles, I haven’t changed any settings. it seems to be arbitrary.
    Any suggestions?
    SC
    (relative newbe)
    Steve Cohen replied 17 years, 5 months ago 2 Members · 2 Replies
  • Tom Brooks
    April 8, 2009 at 2:13 pm
    Just double check about the handles. Also, zoom into timeline (Command +) to make sure you don’t have a single frame of slug or another clip between the clips by chance. Another quick way to get handle room on a still is to use the slip tool (s). It gives you a quick look at where your clip sits within the total length of the media.
  • Steve Cohen
    April 8, 2009 at 3:58 pm
    Handles are good, no material between the the A & B side of the cut. It’s a mystery. Thanks for your response, Tom.
    SC
