Activity › Forums › Sony Cameras › Tripod Help: 542ART/519 Vs. FSB-6/Carbon Fiber
  • Joe Tyler
    August 7, 2009 at 2:47 pm
    With any Fluid head I’d pay special attention to the weight limit.
    On such a small tripod you may have a few pounds of sway, but generally the fluid heads are pretty accurate with their limitations.
    It may not affect your panning, but a full vertical tilt up or down could slip and drop your camera or burst something inside the head.
    You can find great used tripods – Sachtler Videop 18P – former news tripods that will be much better with the heavy load.
    http://www.killianthered.com
    DP in the Washington DC Area
    EX3 Owner
  • William Mims
    August 7, 2009 at 7:58 pm
    B&H Video, out of NY, has a Cartoni HiDV Fluid Head ($ 749).
    Let me just say this, save the difference elsewhere and get the Cartoni. Hands down, the sweetest fluid head I have ever used. You will not regret it. 75mm bowl, I got a nice tripod for under $ 250. The Cartoni handles my EX3 with extra stuff on it just fine, it’s velvet smooth, and very nice. It has some nice lock down features and you can tilt it +90 degrees.
    Here’s a flash I learned the hard way-cheap fluid heads are not fluid, they are friction with a honey like substance that will ozz out on a hot day in the trunk-then your sunk for sure. trust me. A tripod/fluid head is not the place to cut corners. At one time or another I have used them all, Sachs, O’Connors, Vinten, etc. This Cartoni is the best I have used.
    Mims
