Activity › Forums › Adobe After Effects › Trimming logic
  • Trimming logic
    Posted by Martin Mark on March 21, 2015 at 11:39 pm
    I’m new to AE and I can’t get a hold of it’s trimming logic.
    My clip is a bit too long so I trim it from the beginning and from the end with trim comp to work area.
    I want to use time remapping. I enable it, but the keyframes are not going to the beginning and end on the trimmed clip, but to the beginning and end of the original clip.
    How could I trim the clip so there wouldn’t be anything left, but the short clip itself?
    Walter Soyka replied 11 years, 6 months ago 3 Members · 3 Replies
  • Declan Smith
    March 22, 2015 at 12:25 am
    Trim your clip as you have been doing, then pre-compose it. You should be able to retime the precomposed clip as desired as its start / end will be as you selected on the original clip.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
  • Martin Mark
    March 22, 2015 at 9:27 am
    Thank you, Declan!
  • Walter Soyka
    March 24, 2015 at 1:34 am
    I’ve just published a script to enable time-remapping to trimmed layers’ extents.
    Presenting keen-TrimRemap:
    https://www.keenlive.com/renderbreak/2015/03/keen-trimremap/
    The blog post includes instructions on how to use the normal Ae shortcut for time-remapping to run this script instead, essentially making this the default time-remapping behavior in Ae. Feedback is always welcome.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
