Activity › Forums › Adobe Premiere Pro › Trimming in Source Panel
  • Trimming in Source Panel
    Posted by Eden Maxwell on August 22, 2012 at 10:58 pm
    Premiere CS6 / iMac 10.6.8
    When I trim a clip in the Source panel and hit the spacebar, the entire clip plays instead of only the trim.
    Solution welcome.
    Eden Maxwell replied 14 years, 1 month ago 2 Members · 4 Replies
  • Angelo Lorenzo
    August 23, 2012 at 1:07 am
    Shift+Control+Spacebar, probably Shift+Command+Spacebar on Mac
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Eden Maxwell
    August 23, 2012 at 2:30 am
    Thanks for the suggestion, but nothing happens on my iMac.
    I did find out that if I select loop, then the clip does play to trim in the source monitor.
  • Angelo Lorenzo
    August 23, 2012 at 7:24 pm
    Go to Menu Bar > Edit > Keyboard Shortcuts… and scroll down a bit to find “Play In to Out”, this is the shortcut you’ll need. Feel free to assign it to an easier key combo.
    Angelo Lorenzo
  • Eden Maxwell
    August 24, 2012 at 12:39 am
    Thanks for that tip.
    option + k = plays in and out
