Activity › Forums › Adobe After Effects › Trimming for the first time
  • Trimming for the first time
    Posted by Ladycoralie on June 6, 2006 at 8:12 am
    Hi all! I’m a newbie and I need help trimming for the first time. I have an mpeg that goes for 13 mins, but I only want to use a specific part of it that lasts for one minute. I’ve managed to put the mpeg in the timeline, but now I’m stuck. I’ve tried setting an in and out for the times when the frames I want to use appear but nothing happens when I hit ram preview. What am I doing wrong? I need this for an assignment (my first) and am going crazy. Cheers!
    Deadittex replied 20 years, 3 months ago 2 Members · 3 Replies
  • Deadittex
    June 6, 2006 at 5:14 pm
    go to the point in the time line where your In point it.. hit shift+command (control If your a PC weenie) + D the layer will split .. HIghlight and delete what you don’t want
  • Ladycoralie
    June 7, 2006 at 12:00 am
    Thanks DeaditteX. Do I then do the same with the outpoint? I’m assuming that you mean by going to the point in time I point my mouse at it? Then I highlight the rest and delete? Sorry. I am completely new at this.
  • Deadittex
    June 8, 2006 at 5:19 pm
    Yeah move teh time line bar the one that shows you where in the time line you are to the point you wanna make the “cut and do the Comand SHift D command .. then do it fo the out point as well .. It will split the layer highlight the layer that is before for in point, or after for out point and then delete that layer..
