Activity Forums Adobe After Effects Trimming a Precomp with Twixtor
  • Trimming a Precomp with Twixtor
    Posted by Marie-christine Laniel on January 6, 2019 at 7:48 pm
    Would like some help on this issue if possible ☺
    I’m using the plugin twixtor on a precomp. I made a slowmotion on a footage of a girl that is moving and everything was working just fine. However, I realise that, because the clip has a simple cut in the middle, the slow motion creates a weird frame blending at this point. So I wanted to split my precomp, shorten the duplicated precomp so that I don’t see this part that I don’t want to see, and then put those 2 precomps side by side in time. I thought that it would be really easy, but I realised that when I try to move the duplication in time, it’s like I had never make a cut and the time is still linear. So I never get to remove the part that I don’t want. I tried to duplicate my precomp in the project panel and change the name, so that they could be unique, but it’s doing the same thing (and no, I don’t have other precomp inside my precomp).
    This is the weird frame blending I was talking about
    This is the split I made to the comp, and I had shorten the part that I don’t want
    And this is when I try to put them side by side, you can see that a little further in the duplication, the wierd frame blending happen again. It’s like the cut that I made have never happen.
    I tried to explain myself the most clearly as I could, I hope it’s going to be enough!! Thanks for all the help you guys can give me.
    Marie-Christine Laniel
    Marie-christine Laniel replied 7 years, 8 months ago 2 Members · 2 Replies
