Activity Forums Apple Final Cut Pro Legacy Trim Tool FCP 7.0.3 Makes Audio Pop?
  • Trim Tool FCP 7.0.3 Makes Audio Pop?
    Posted by Benjamin Byleen on November 22, 2010 at 3:43 pm
    Hi all:
    Has anyone noticed any faulty behavior using the trim tool in Final Cut Pro 7.0.3? Specifically, when I use the trim tool to modify an edit point by a few frames (forward or back), thereafter, the audio playback of that sequence is distorted — pops, cracks, stutters, not smooth, even areas outside the trim. (An export of that sequence has no problems).
    If I were to trim that edit by hand (not using the tool), the audio stays fine.
    Trashed prefs, repaired permissions, reinstalled FCP from scratch, ran speed test on my drives, everything looks good / acts good, until I use that trim tool.
    Thoughts? Suggestions on fix? (For now I’m just not using the tool at all to doubly confirm no further audio distortions without it).
    Ben
    FCP 7.0.3
    MacOSX 10.6.4
    XSan connected
    MacPro 8-core
    4GB Ram
    1080i 59.94 Apple Pro-Res HQ Sequence / Media
    Blackmagic Decklink HD Extreme (driver vers. 7.9)
    Jerry Hofmann replied 15 years, 10 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    November 22, 2010 at 5:43 pm
    I’ve not seen this behavior at all, and about the only difference between my setup and yours is that my media is local and not being accessed through an XSan…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Benjamin Byleen
    November 22, 2010 at 6:16 pm
    Thanks for the response.
    Yeah I was kind of leaning against a glitchy tool / FCP version but had to ask. Currently I am looking into hardware causes.
    Any other responses still welcome of course!
  • Jerry Hofmann
    November 22, 2010 at 10:16 pm
    That’s a good point… I do hear pops if the media is an MP3 or other highly compressed file.
    Jerry
    Current DVD:
  • Benjamin Byleen
    November 22, 2010 at 11:20 pm
    Thanks again for responding. Actually that was my first thought and I made sure that everything was 48khz.
    I’m currently investigating the below error message and whether it is related or not. My rather unscientific thinking is that if I have a flaky RAM chip, the necessary overhead for the trim tool is not met. System profiler reports that the RAM is “OK” but I’ve heard (heresay of course) that’s not always 100% reliable. I’ve searched online for this error, but no posts that really relate to mine. Anyone seen these errors before and know specifically what they mean?
    Nov 22 10:57:16 Final Cut Pro[45715]: Final Cut Pro(45715,0xde7500) malloc: *** mmap(size=268439552) failed (error code=12)\n*** error: can’t allocate region\n*** set a breakpoint in malloc_error_break to debug
    Nov 22 10:57:16 [0x0-0x139139].com.apple.FinalCutPro[45715]: Final Cut Pro(45715,0xde7500) malloc: *** mmap(size=268439552) failed (error code=12)
    Nov 22 10:57:16 [0x0-0x139139].com.apple.FinalCutPro[45715]: *** error: can’t allocate region
    Nov 22 10:57:16 [0x0-0x139139].com.apple.FinalCutPro[45715]: *** set a breakpoint in malloc_error_break to debug
    It seems somewhat implausible but I cannot ignore the error, so maybe going to try a few new sticks of RAM, and see whether it gets rid of the error and the audio problem.
    Thanks again all!
    Ben
  • Andy Mees
    November 23, 2010 at 12:53 am
    Just thinking out loud here, but if its popping whilst monitoring via the BMD card it might be an idea to test to see if the Mac’s built-in audio output presents the same issue and/or try without the BMD drivers installed. (Just in case there is some kind of driver conflict going on). And does the issue present on your system regardless of source and sequence settings, or are you finding it’s specific to the particular config you’re working with right now?
  • Jerry Hofmann
    November 23, 2010 at 1:52 pm
    You can remove ram chips one at a time to see if the issue goes away before you buy more…
    Jerry
