Activity Forums Apple Final Cut Pro Legacy Trim Project, Deleting unused media, media manager–NO RESULTS
  • Trim Project, Deleting unused media, media manager–NO RESULTS
    Posted by A.lee on July 6, 2005 at 10:11 pm
    HI-
    I’m trying to free up some drive space. Using the Media manager, I am trimming the project and sequences. After I do so, however, the file sizes are the same? Any thoughts on what I am doing wrong or where the deleted unsed clips have gone?
    for instance,
    orginal: 136 GB
    Modified: 120 GB
    After going through the steps to trim the sequences, I still get the same amount of space, as if I had done nothing ( but waste the hour or so it takes to “do it”)
    1. selected sequence or sequences
    2. control click sequences, and choose Make Sequence clips independent.
    3. media manager:
    “use existing”
    check box for delete unused media
    check box for handles
    choose exisisting file names.
    uncheck project section
    These steps were taken from a tutorial by Andrew balis, found on Kenstone.net.”Media management in Final cut Pro 4″
    Job Van nuenen replied 21 years, 1 month ago 5 Members · 5 Replies
  • Jerry Hofmann
    July 7, 2005 at 4:06 am
    How much more media do you expect to be able to delete?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Sean Oneil
    July 7, 2005 at 11:36 pm
    Are you using FCP5?
  • Paul Kelleher
    July 11, 2005 at 8:02 pm
    I have the same problem-and its driving me nutty!! No trimming- no matter what settings I change in MM window. For a 4 min timeline, in one case, i get 1.3 gb of media remaining. should drop to about 860 Mb, I think. I’ve tried this on several project files and NEVER see any trimming.
    Paul
  • Job Van nuenen
    July 12, 2005 at 8:39 am
    Same problem here, Trying to reduce and recapture an old FCP4.5 project in FCP5. Media Manager doesn’t seem to delete the unused footage. I took the project back to one of out other machines that’s still running in FCP4.5 (my luck that I didn’t have the time to upgrade all the machines..) And MediaManager works perfectly.
    I tried the https://www.lafcpug.org/FCP_4_trim_dang_it.html workaround on FCP5 but that doesn’t help me out either.
    Any thoughts? or is the Mediamanager in FCP5 crooked?
    Regards,
    Job
    Media100/after-effects/Combustion/FCP/Flint/Flame/Inferno..
    Thank heavens; there’s a sign of progress here..
  • Job Van nuenen
    July 13, 2005 at 7:14 am
    Yep I’m in FCP5, is ths a known issue? And is it fixed in the 5.0.2 update, Apple provided today? isn’t mentioned in the docs though..
    any help would be appreciated.
    regards.
    J
