Activity Forums Adobe After Effects Trim out shortcut leaves a frame at the end. Why?
  • Trim out shortcut leaves a frame at the end. Why?
    Posted by Balazs Frank on August 10, 2010 at 7:56 pm
    funny thing: when I trim the out point of a layer with the Alt (Option) + ] shortcut, it does trimming, but always leaves one single frame behind the trim point. Why does it work like this?
    thanks,
    B.
    Balazs Frank replied 16 years ago 3 Members · 3 Replies
  • Todd Kopriva
    August 10, 2010 at 8:10 pm
    The Out point is the _beginning_ of the last frame that is played.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tudor “ted” jelescu
    August 10, 2010 at 8:11 pm
    In AE, the cursor on the timeline is at the beginning of a frame and not at the end. So whenever you are trimming you have to cosider the last frame, that frame which is after the cursor- that should be easy enough since that is the frame you see in the viewer anyway.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Balazs Frank
    August 11, 2010 at 8:37 am
    Thanks, good to know.
