Activity › Forums › Adobe After Effects › Trim nested comps by length of main composition.
Posted by Konstantin Kartashov on November 12, 2016 at 7:31 amHi,
I just wanted to know is it a way to trim all nested precomps to same length as main comp? Some scripts?Konstantin Kartashov replied 9 years, 10 months ago 2 Members · 2 Replies -
Roei Tzoref
November 12, 2016 at 9:32 pmlooks like this is what you were looking for: https://aescripts.com/rd-compsetter/
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials -
November 13, 2016 at 5:43 amMmmm…. not really. I`d like to keep nested comps inside main comp, and match start and end of these comps to start end of main. And also don`t know the exact length of main comp (or rather comps) to set it manually.
In case of using the script you offer I have to keep in mind the length of main comp, then pick the right nested comps from different folders of project to set it for each of them, which is not very convincing. And as far as I understand the length of nested comps will be set from the start, while I need to keep time period currently visible in the main comp.
Anyway thanks for trying to help 🙂
