Trim Monitor Defaults to Option & Arrow keys – No Like!
Hi there,
I’d like to know if there’s a way to make the Trim Monitor in Premiere Pro CC behave the way it does in previous versions ie. you now have to hold down Option & an Arrow key (left or right) to move through frames.
In the past, you just used the Arrow keys. If you try that now the Trim Monitor will just turn itself off.
I know it’s nit-picky but it just annoys me to have to use that extra key when it was so clean and simple before. I’ve tried to find a way to change it in the Keyboard Shortcuts but those options no longer exist (as they did previously) – they’ve gone!
Does anyone have an idea how to change this back to just a one key procedure?
Thanks in advance,
ALEX
