Activity Forums VEGAS Pro trim cut from lots of videos
  • trim cut from lots of videos
    Posted by Ca tourne et Joupiter on January 10, 2016 at 5:34 pm
    Hi everybody.
    I have lots of hours from Making of & Behind the scene of big French movie prod.. Shooting was really hard during 4 months and I had no time to make some cleaning…
    Now i’m in front of my drives and need a way to fast first select before starting editing process. I would like to use selected parts to be saved for edit in a new clean folder/workflow/drive. But using trim option, I can onl create sub clips wihch are linked to their mother file.
    How to fast save them and without any quality loss ? ( Best would be to keep the same orginal codec/res etc…)
    The only option I found is to put them on time line and selecting each as “Render to New track”
    In this case, which codec and parameters to use, to reimport it in vegas without loss ?
    I have mix of UHD 50p , UHD 25p, AVCH HD 50p, all from Panasonic cameras
    (HC x1000 /vx870 / lx 100)
    Thanks guys to share your expertise !
    Fabrice
    Ca tourne et Joupiter replied 10 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
