Activity Forums Adobe After Effects Expressions Trim Comp to Work Area
  • Trim Comp to Work Area
    Posted by Nick Leigh on May 9, 2014 at 3:39 am
    I have searched google and this forum and found the following code to trim my comp to the work area:
    videoComp.workAreaDuration = 0.6;
    videoComp.ramPreviewTest("",0.33,"");
    videoComp.workAreaDuration = settings.compLength;
    app.executeCommand(app.findMenuCommandId("Trim Comp to Work Area"));
    I am using AE CS5
    The problem is that I am getting an error every time I run my script. The error states:
    Unable to execute script at line 103. After Effects error:RAM Preview needs 2 or more frames to playback. Line 103 is the ramPreviewTest line.
    Thanks for the help.
    CS5 Production Suite
    Nick Leigh replied 12 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    May 9, 2014 at 5:45 pm
    you would commonly see that error if the cti was at the end of the comp work area and tried a ram preview from current time.
    if that’s the case here, then you may need something in the script to either do a ram preview for the whole work area, or move the cti from the last frame of the comp/work area.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Nick Leigh
    May 9, 2014 at 9:00 pm
    Ok so I tried your solution and set the current time to 0 and I was still getting the same error. Here is what I am doing:
    videoComp.time = 0;
    videoComp.workAreaDuration = 1;
    Is there a way to simply set the comp duration of length?
