Activity Forums Adobe Premiere Pro Trim audio and video with T shortcut even if the audio isn’t cut at the same place than the video ?
  • Trim audio and video with T shortcut even if the audio isn’t cut at the same place than the video ?
    Posted by Marc De coster on January 11, 2016 at 12:10 pm
    Hi.
    I’ll have to work on a TV show at the end of the month, I want to use Premiere, and I’m practicing my shortcuts 🙂
    Trimming will be a huge part of the editing of course so I want it to be fast.
    Here is the thing:
    Let’s pretend that audio isn’t cut at the same place than the video, like this
    When I hit T to open the trim window Premiere doesn’t select both audio and video. It means that I have to click on each cut to select them. It’s really boring.
    Do you know a way to select that edit (video and audio) in the same time?
    Thank you all.
    Marc De coster replied 10 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
