Activity Forums Adobe After Effects Triggering nested comps to play only when desired
  • Triggering nested comps to play only when desired
    Posted by Oli Sansom on February 12, 2009 at 3:23 am
    Hi all
    Is there an easy way to have a nested composition sit static on it’s own first frame, and only begin to “play” once triggered by a call in the parent composition?
    Cheers
    Oli Sansom replied 17 years, 7 months ago 2 Members · 2 Replies
  • Darby Edelen
    February 12, 2009 at 7:01 am
    It sounds like you want to enable time-remapping on your nested composition. You can move the keyframes to retime the composition, or even apply expressions to alter the time remap property values.
    Darby Edelen
  • Oli Sansom
    February 12, 2009 at 7:42 am
    Cheers Darby. Coming from a flash animation background, I’ve found it hideously time consuming and messy moving complex keyframed animations along to different parts of nested comps timelines, in accordance with a change to the parents animation timing. I’ll take a further look into time remapping 🙂
