Activity › Forums › Adobe After Effects Expressions › Trigger keyframes WITHOUT markers
  • Trigger keyframes WITHOUT markers
    Posted by Greg Digenti on June 29, 2021 at 6:18 pm
    I realize you can trigger keyframes with markers, but in this case I want to be able to trigger them when a slider value reaches a certain number.
    So basically, I have a layer with a slider, and the starting keyframe value is 0 and the end value is 100. Then I have a number of layers that I want to start playing their 2 position keyframes based on the percent finished of the slider value, so they slide in one after the other. Then if I adjust the slider’s end keyframe, all of those layers start time will adjust accordingly. Doing this with markers would be wayyyy too time-consuming for this project.
    Greg Digenti replied 5 years, 3 months ago 1 Member · 1 Reply
  • Greg Digenti
    June 30, 2021 at 5:31 pm
    Well I can see why no one jumped to help with this… I figured it out, but it ended up being pretty complicated. Probably not as complicated for someone better at math and coding, though.
