Activity Forums Adobe After Effects Expressions Trigger Animation through layer Marker
  • Trigger Animation through layer Marker
    Posted by Nathaniel Logan on November 21, 2018 at 7:18 pm
    Hi Dan,
    I was using one of your expression to trigger the keyframes of text layer animation, can we use the Marker name to trigger the Animation so that, i can insert a new marker for animation “Out” so that the animation doesn’t Override.
    preroll = 1;
    L= thisComp.layer("Controller");
    n = 0;
    t0 = time + preroll;
    if (L.marker.numKeys > 0){
    n = L.marker.nearestKey(t0).index;
    if (L.marker.key(n).time > t0) n--;
    if (n < 1){
    t = 0;
    }else{
    t = t0 - L.marker.key(n).time;
    valueAtTime(t)
    Nathaniel Logan replied 7 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 21, 2018 at 8:17 pm
    I haven’t tested this, but if I understand what you’re asking, I think it would be like this:
    preroll = 1;
    t = 0;
    try{
    if (t0 > L.marker.key("Out").time){
    t = t0 - L.marker.key("Out").time;
    }catch(e){
    valueAtTime(t)
    Dan
  • Nathaniel Logan
    November 22, 2018 at 5:23 am
    Thank you, So much Dan. Works like Charm! ????
