Activity Forums Adobe After Effects Triangular (stroked) grid with individually animated triangles
  • Richard Garabedain
    January 22, 2019 at 3:47 pm
    Do you have element 3d? IF so you could make a plane within element 3d. set faces to triangles and then .(after you increase its geometry) use the 3d distortion – noise under element 3d settings
  • Shane Smith
    January 22, 2019 at 3:49 pm
    Thanks Richard,
    No I don’t have Element 3D, yet. But I’m always looking for a good reason to get it. 🙂
  • Kalleheikki Kannisto
    January 22, 2019 at 5:24 pm
    You could make two square grids and slant them in the opposite directions by 30 degrees, align the corners to match and use lighten mode to blend them.
    Senior Graphic Designer
