Activity Forums VEGAS Pro triangles between clips
  • triangles between clips
    Posted by Gary & yvonne on December 27, 2005 at 7:26 am
    I think I know the answer to this but not sure……When you connect to clips together on the timeline theres a triangle at the top of where they connect…..then sometimes it’s only a half a triangle and a different color………..Could you clarify the meanings of the triangle….Also sometimes when the clips have the triangle connecting them, that isn’t always a clean connection because i can see it’s not a clean cut even if I have snap together selected.
    Thanks for your help………………Gary
    Edward Troxel replied 20 years, 8 months ago 2 Members · 1 Reply
  • Edward Troxel
    December 27, 2005 at 2:36 pm
    You can really notice if it’s not a “clean” cut if you have a fade in or fade out on one of the clips and it disappears. You need to zoom in on the timeline and verify the left clip ENDS on a frame boundry. If it doesn’t, shorten it until it does and all should be fine.
    I’ve never investigated the different colors I’ve seen to figure out what each color might mean and have not seen such a description.
    Edward Troxel
    JETDV Scripts
