Activity Forums Adobe After Effects Trapcode Particular Textured Sprites "twitching"
  • Trapcode Particular Textured Sprites "twitching"
    Posted by Ben Hartley on May 28, 2021 at 12:26 am
    I have created a flowing ring of leaves by tweaking a preset in Trapcode Particular. It is using a custom textured sprite. The linked Pre-comp for the sprite texture holds a seamlessly looping .MOV.
    – Please see attached clip that shows the strange “twitching” I am trying to fix.
    – The sprite .MOV and all comps are 25fps.
    – The particular layer is also flashing white which I need to fix too!
    Any thoughts would be much appreciated!
    Thanks in advance
    Ben
    Ben Hartley replied 5 years, 3 months ago 3 Members · 5 Replies
  • Ben Hartley
    May 28, 2021 at 5:04 pm
    The particular layer also –
    – no aux system
    – Physics – Fluid – vortex tube
    – Emitter type – Tube ring OBJ
  • Eric Santiago
    May 28, 2021 at 5:11 pm
    I haven’t done any of this in a long time but I do recall something to do with random.
    I had the same issue with an older project where the point particles would snap.
    Sorry that’s all I can remember.
  • Ben Hartley
    May 28, 2021 at 5:20 pm
    Thanks Eric. I have played around with all the random settings with no success. I will probably have to start from scratch and try get my movement shape a different way, which is a shame as this is the perfect formation. The problem seems to go away when I use the textured sprite from scratch.
  • Graham Quince
    May 29, 2021 at 10:11 am
    If the problem goes away when you start from scratch, it makes me wonder if there was a glitch in the original preset version that was compensated for.
    Have you checked the Turbulence settings in Physics?
  • Ben Hartley
    June 3, 2021 at 5:45 pm
    Thanks for your responses, I have started from scratch and the twitching has gone but there is still some white frames flashing annoyingly.
