Activity Forums Adobe After Effects trapcode particular problem!
  • trapcode particular problem!
    Posted by John Damiani on November 17, 2011 at 11:30 pm
    i am following some tutorials on making a crowd, and i am running into a problem the tutorials dont cover.
    i am using custom sprites, and in order to make light pass through the particles, i have to make the layer 3d, however, when i make the layer 3d, no matter what i do, i cant get the particles to come back! they are completely gone, i have search everywhere on the comp, check at different times during the comp, i even tried deleting everything but the sprite and the particular layer from the comp and the particles STILL wont show up! looking on the internet it seems that particular does not play nice when its on a 3d layer, but how am i going to get the light to shine through the particle? is there any other way to get light transmissions on this layer?
    i would appreciate any help i could get! if anyone knows of a way i could get light to pass through these sprites i would be most grateful
    Kevin Camp replied 14 years, 10 months ago 5 Members · 11 Replies
  • 11 Replies
  • Roland R. kahlenberg
    November 18, 2011 at 1:28 am
    You’ll have to fake the lights or use Trapcode 2.0’s Shading properties.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • John Damiani
    November 18, 2011 at 2:04 am
    i have shading on, thats not the problem, the light is hitting the 2d objects just fine, however, its not allowing any light through the images, i dragged a light down to the bottom to show what i am talking about in this picture, as you can see no illumination happens on the objects between the light and the camera. i need to be able to get the light to go through the object
    https://i87.photobucket.com/albums/k125/adecoy95/light.png
  • Raza Ahmad
    November 18, 2011 at 2:21 am
    I’m going off memory here, but don’t particular particles interact with lighting by defaults (as in, without the solid containing the effect being a 3d layer?)
    https://www.redgiantsoftware.com/products/all/trapcode-particular/features/#tabs
    The features list confirms this…
  • John Damiani
    November 18, 2011 at 2:34 am
    your right, it should, i am seeing some interaction with the lights, (the particles are being illuminated), but i cannot seem to be able to get the light to pass through them. 3d layers cause the particles to cease completely, so what your looking at is the particular solid on a 2d layer
  • Sam Smith
    November 18, 2011 at 3:31 am
    Roland is right. Use Particular 2, do not make the layer 3d, turn on shading, and move your light around.
    -Sam
  • John Damiani
    November 18, 2011 at 2:50 pm
    this is particular 2.0 btw
  • Kevin Camp
    November 18, 2011 at 3:02 pm
    it sounds like you want the particles to cast shaddows, and i don’t think particular will do that (i know v1.5 can’t).
    if that is what you are after, then you’ll need to fake the shaddows.
    you may be able to build the shaddows into the particles, but since you’re light sources are point source, it may be hard to make that look correct (distant light sources may might be able to make this method believable).
    a second particle system, same settigns, but with a custom particle that would be placed at the feet of the current custom particles might work. then you’d need to use an effect like fast radial blur (or shine) with the center placed near the light souce might give believable results.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Damiani
    November 18, 2011 at 3:07 pm
    all i want is the light to pass through, under material settings its called “light transmission” but material settings only show up for 3d layers, so i cant get it for particular, is there any way to get it for particular? i dont need it to cast shadows on the floor or anything
  • Kevin Camp
    November 18, 2011 at 3:37 pm
    so it sounds like you just don’t need the particles to accept lights so you can see them regardless of their relationship to lighting…?
    i don’t have v2 so i don’t know where the setting is for that, but i would assume that there is one.
    if not, then you could put the particle system layer and custom particle layer in a precomp, that way it shouldn’t respond to lighting.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Damiani
    November 18, 2011 at 3:53 pm
    well, no i need it to respond to lights, but i want both sides of the sprite to be lit, currently only the side the light is shining on lights up, and the other side stays hard black, looking to let the light pass through to give me shine on both sides
