Activity › Forums › Adobe After Effects › Trapcode Particular – Custom Particle Opacity
  • Trapcode Particular – Custom Particle Opacity
    Posted by Thali Ferreira on April 4, 2016 at 7:07 pm
    Hello there!
    I am starting to learn AE and particles in general and I was doing some exercises with trapcode particular. I created a leaf as custom particle and made it grow on a branch, but some particles have the opacity low after they finished growing even though all the opacity settings are on 100%. Do you guys know why? I am using Sprite as a particle type. Here is the link for the picture:
    https://www.trapcode.com/storage/upload/customparticle.jpg
    Chris Keller replied 10 years, 5 months ago 3 Members · 3 Replies
  • Kalleheikki Kannisto
    April 4, 2016 at 8:52 pm
    Are you using a Layer as the Emitter? If you hit a semi-transparent pixel, you’ll get semi-transparent particles. If so, you can fix that by using curves adjustment on the alpha channel of the layer (precomp it so it reads the curves adjustment).
  • Thali Ferreira
    April 4, 2016 at 9:07 pm
    Makes sense!yeah, I am using the branch layer as emitter, which layer should I do the adjustment on? The particle or emitter layer?
  • Chris Keller
    April 4, 2016 at 11:30 pm
    do it on the layer you are using as your emitter, in this case the branch.
