Activity › Forums › Adobe After Effects › Trapcode MIR – Filling between a wireframe
  • Kalleheikki Kannisto
    June 22, 2016 at 7:38 am
    Hi Lee,
    I didn’t remember that Mir was so bad at filling faces at the same time as drawing wireframes, but here’s how you can make it work:
    Use white material.
    Shader: Phong shader
    Draw: Front Fill, Back Wire
    Blend: Normal
    DepthBuf: On
    Rotate you Geometry to Z: -90, X: 90, Y: 0
    Create a spot light and place it directly above the geometry at a good distance.
    While both the front face wireframe and the back face fill are white, the light position causes the back face to be black.
    It’s not perfect, but it will probably work for your purposes.
    June 22, 2016 at 7:44 am
    … oh well, it’s actually much easier in Mir 2 ( I have version 1). In Mir 2 you have a second-pass wireframe option.
  • Lee Phillips
    June 22, 2016 at 11:59 am
    I also have version 1 as I’m using CS5.5. This is a hobby for me and I can no way afford CC.
    I think I’ve pretty much got it. It still has a little bit showing through from being the mountain, but with a bit of fettling with the fog, it should clean up alright. :]
    Thank you for your help!
