Activity Forums Adobe After Effects Trapcode Lux Settings ?
  • Trapcode Lux Settings ?
    Posted by Andy Joseph on November 9, 2009 at 7:00 am
    I’m using trapcode lux in one of my project. Now i want only some of the lights to get affected by trapcode lux & not ll the lights. I tried moving ‘light layers’ above & below ‘lux solid layer’ but that doesnt work.
    Secondly, Lux lights are also visible even if a solid layer or any comp is placed between light & camera. I dont wanna lights to be visible if any object is placed in between but its not happening.
    Experts pls help me with your skills.
    Thnx
    Andy
    Andy George replied 16 years, 10 months ago 2 Members · 1 Reply
  • Andy George
    November 9, 2009 at 9:50 am
    Andy-
    [Andy Joseph] “Now i want only some of the lights to get affected by trapcode lux & not ll the lights”
    You can select lights effected by lux under the general section of the plug in
    modifying the “use lights that are” and “name starts with” Parameters.
    Page 13 of the lux manual explains it well
    video.thecastsite.com/…/Trapcode/Lux…/TrapcodeLuxManual.pdf
    [Andy Joseph] “Lux lights are also visible even if a solid layer or any comp is placed between light & camera.”
    Yes this is a limitation of lux. It has no built in obscuration (ability to “hide” itself behind other layers)
    It can be a useful plugin if composited carefully. But if you need more control you
    might want look for some volumetric lighting tutorials and work with AE’s built in tools.
    -Andy
