Activity › Forums › Adobe After Effects › Trapcode form doesn’t recognize rotobrushed layer’s transparency.
  • Trapcode form doesn’t recognize rotobrushed layer’s transparency.
    Posted by Johnny Smith on July 24, 2011 at 10:41 am
    Applied form to a solid layer ( layer set to visible ) and used a rotobrushed layer ( hidden ) as a source for the color and alpha map. Functionality set to RGB to RGB. Issue: the comp’s background is no longer transparent. How can I fix this? Watched all of the tutorials on form and can’t figure this out. Thanks so much in advance.
    Johnny Smith replied 15 years, 2 months ago 2 Members · 3 Replies
  • Todd Kopriva
    July 24, 2011 at 12:32 pm
    Precompose the layer with the Roto Brush effect, and use the new precomposition layer as the source for the alpha channel.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Johnny Smith
    July 24, 2011 at 11:00 pm
    That did NOT make a difference, unfortunately.
  • Johnny Smith
    July 24, 2011 at 11:30 pm
    switched to RGBA instead of RGB and yes it worked! thank you very much.
