Activity Forums Adobe After Effects Expressions Trapcode Form and Expressions
  • Trapcode Form and Expressions
    Posted by Brian Smith on May 27, 2008 at 7:58 pm
    Hey Guys- I’m working with Trapcode Form. I need to tie an X-Rotation property to increase with the comp’s time. Essentially, so as the playhead moves forward in time, the X-Rotation property increases at the same rate.
    -BS
    Brian Smith replied 18 years, 3 months ago 2 Members · 2 Replies
  • Bert Brown
    May 27, 2008 at 8:22 pm
    just hold option, click on the x rotation and type in “time” and that’ll do it (if i understand you correctly)
    it’s going to be mighty slow, though. might want to add some “*10” or “*100” or something.
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
  • Brian Smith
    May 27, 2008 at 8:33 pm
    Wow, that was easy enough. I did try that, but I needed to add a *20 (which I didn’t do initially) at the end to see the animation come to life very quickly. Thanks for your help!
