Activity Forums Adobe After Effects Expressions Trapcode 3D Stroke – attach ball to endpoint
  • Trapcode 3D Stroke – attach ball to endpoint
    Posted by Andres Torres on June 15, 2009 at 9:00 pm
    I created a pendulum with a string and ball using Trapcode 3D stroke for the string.
    I wanted to know if it is possible to calculate/pickwhip the string’s endpoint position. I want to parent the ball to the endpoint so that it is attached to the end of the string no matter how I transform it.
    Without this value, the string/ball relationship is easily broken when using the bend and transform features of 3D Stroke.
    Andres Torres replied 17 years, 3 months ago 2 Members · 2 Replies
  • Andres Torres
    June 15, 2009 at 9:08 pm
    Yeah, that was my 1st thought. I just didn’t know if it could be done with expressions. Maybe Peder Norrby would have to write that into the plug-in for that to be possible?
  • Dan Ebberts
    Maybe you could animate the string first, track its end point, then attach the ball via an expression.
    Dan
