Activity Forums Maxon Cinema 4D transparent tunnel walls, only want inside visible
  • transparent tunnel walls, only want inside visible
    Posted by Graham Quince on September 29, 2007 at 7:33 am
    Hi everyone,
    Hoping someone can help me. I’m pretty new to C4D and work has just bought me R10. I’ve trying to create an energy tunnel using a circle and freehand spline feeding into a sweep nurbs.
    So far so good. The problem comes in that I’ve created the texture in photoshop and it contains transparent elements. I only want the tunnel to be seen from the inside, so when you see through the wall of the tunnel, you don’t see the rest of it.
    It’s probably got something to do with the texture project, but I’m stumped. Can anyone help?
    Graham
    Graham Quince replied 18 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
