Activity Forums Adobe After Effects Transparent Text??
  • Transparent Text??
    Posted by Ashley Heilig on October 22, 2012 at 3:13 pm
    I’m working with a client that really wants this scene but I am stumped on how it was done. I know how that background was done but when it comes to the text I’m clueless at this point.
    https://youtu.be/CDY4ws0YE3A?hd=1&t=1m38s
    Please Help
    Ashley Heilig replied 13 years, 11 months ago 2 Members · 2 Replies
  • John Cuevas
    October 22, 2012 at 8:45 pm
    Do you mean the text that you can see in the poster frame(TATO). The method I would use would be to create my text layer and texture, and precompose it. Then to get the text to have varying degrees of transparency I would create a solid and add fractal noise to it. Place that above the text layer and change the text layer’s track matte to a luma matte. For fun you could set keyframes on the fractal noises evolution to have the opacity change a bit. Finally I would play with the final transfer mode of the text(looks like an additive mode).
    Here’s a quick and dirty example project for you to see, perhaps it will give you some other ideas on how to approach this: 4835_textexamplefolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ashley Heilig
    October 23, 2012 at 12:38 pm
    I wasn’t able to open your file, but your directions gave me the exact effect that I was looking for. Thanks so much!
