Activity › Forums › Adobe Photoshop › Transparent Images
  • Transparent Images
    Posted by Joseph Mclachlan on July 22, 2006 at 10:46 am
    Hello,
    I’d like to know how I can preserve transparent images within a photoshop file, then import them into Illustrator without being gigantic (file size)
    The only file that works that I know of is a psd (photoshop) file that has not been flattened.
    any help from the COW would be much appreciated.
    Thanking you,
    Joseph
    Joseph Mclachlan replied 20 years, 2 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    July 24, 2006 at 5:40 pm
    Why do your file sizes need to be small? For most design work, you’re better off not using compressed formats.
    You can try using a 32-bit PNG file out of Photoshop, though I’m not sure how Illustrator will treat it. You can also use a TIFF file with compression turned on.
    JPEG 2000 is another option, though I don’t know if Illustrator supports it, and at the very least you have to grab the plug-in for Photoshop off the install CD.
    Otherwise, not many compressed files support alpha channels. PSD really is your best bet.
  • Joseph Mclachlan
    July 25, 2006 at 10:40 pm
    Thanks Timothy,
    I was creating a file for print . . . However, I wanted to send a proof via email and the file was about 8MB.
    So I had to adjust a low-res file in Photoshop to reduce the file size.
    I was hoping that there could be another method to create a trasparent (alpha) channel that didn’t seem so awkward.
    Thanks for clearing that up for me.
    Take Care
    Joseph
