Activity Forums Adobe After Effects Transparent gif animation doesn’t work?
  • Transparent gif animation doesn’t work?
    Posted by Emil Niemi on April 24, 2010 at 9:09 am
    I’ve 1 last problem in After Effects that i would love to solve.
    This is about animated gifs that are transparently.
    If i put these into After Effects it gets white around!
    So i wonder is there any way to make this get transparently?
    Here’s an example of an animated gif file with transparently on.
    https://i40.tinypic.com/2n0pyt3.gif
    Also tried out the “Luma Key” for this, i nearly made it, but in some way it started to cut on the character
    https://i41.tinypic.com/30hls34.jpg
    Problary any setting there i can solve this.
    But hold on, another problem will appear after this one.
    I want to scale up without get the pixel blurred out.
    So my friend got me a ReSize plugin (instant HD) from red giant that will make the character not to get blurried out.
    But when i’m using this one, the animated gif file gets back to a white square again, as in the beginning.
    Only way i can think of now, which will take me alot of time, is to make them in After Effects, that i put in transparent PNG files and then animate them there.
    Emil Niemi replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
