Activity Forums Adobe After Effects Transparent Background in AE
  • Transparent Background in AE
    Posted by Mark Welch on October 29, 2012 at 2:51 pm
    Still learning here. I composed a simple animated text layer which appears to be composed with a transparent background. When I render it out in Make Movie and import it into Premier, it has a black background. There seems no way to specify a transparent background in AE composition settings.
    Any suggestions on how to make BG transparent? Thanks!
    John Cuevas replied 13 years, 11 months ago 3 Members · 4 Replies
  • John Cuevas
    October 29, 2012 at 2:58 pm
    You need to render your movie with an alpha channel. First double check to make sure you have a transparent background by clicking on the “checkerboard” underneath the Comp Work area, if you see the checkerboard when you click it, you have transparency.
    So press “shift+cntl+/” to add your comp to the render queue, choose your render settings, then choose your output module. You will need to choose one that supports an alpha channel. Quicktime-Animation is a good one, in that it’s lossless and supports an alpha(though it delivers massively sized files). To activate the alpha go to Video Output > Channels and change it from the default of “RGB” to “RGB + Alpha” Now render away.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mark Welch
    October 29, 2012 at 3:33 pm
    that did it – thanks
  • Vishesh Arora
    October 30, 2012 at 7:19 am
    Mark
    I always prefer to make a Custom Template for RGB + Alpha.
    While in Render Queue, Click on the Small arrow head and select make Template. Edit the settings with RGB + Alpha.
    Now, Now can also make this default Output Module and by Pressing Cntl/Cmnd while selecting it form the menu.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • John Cuevas
    October 30, 2012 at 11:31 am
    glad I could help.
    Thinkck.com
