Activity Forums Adobe After Effects transparent background animated gif import from photoshop cs3
  • transparent background animated gif import from photoshop cs3
    Posted by Jim Money on January 3, 2009 at 7:23 pm
    Been trying to import animated gif from photoshop cs3 into after effects with a transparent background and all attempts have failed
    it seems so simple to everybody but me, ive tried everything and the background is always white
    i can get a .psd file to show with transparent background but the animation goes wild (changes scale, shows at many place at the same time…)
    these are the things i already do:
    i click on the toggle transparency grid in after effect
    i save in web and peripherics in photoshop
    i save my images with no background
    so im out of ideas
    Iwona Przebindowska replied 15 years, 8 months ago 5 Members · 8 Replies
  • 8 Replies
  • Fernando Mol
    January 10, 2009 at 3:09 pm
    I know this is not what you are asking, but…
    …why don’t you just export the psd images and import them to AE, using them as a pre-comp.
    GIF images will reduce your colors and, later, if you need to do an adjustment in the animation speed it will be way more complicated than if you manage all the animation inside After Effects.
  • Jim Money
    January 12, 2009 at 3:28 am
    finally i found it
    it was in color mode or color something something in the effects palette
    thanks anyways
  • Reuben Lemer
    January 16, 2009 at 6:38 pm
    Sorry, could you be more specific? I have the same problem. I need to import a gif into after effects with its transparency intact. I dont have photoshop, and Preview (Mac default viewing program) doesn’t seem to save the file with alpha when I try to convert it to png, tiff, or targa. Anyone help?
  • Reuben Lemer
    January 16, 2009 at 8:07 pm
    Eh, now I’m confused, is an alpha channel and transparency not the same thing? If not how do I convert gif transparency to an alpha channel?
  • Jim Money
    January 17, 2009 at 4:10 am
    hi,
    You can eliminate the white background using the “Color Key” feature in AE
    go to effect> (mask?) > color key then use the (thing) and click on the background image
    my copy is in french so it might not be mask but i think it is
  • Reuben Lemer
    January 17, 2009 at 7:30 am
    No, my images is just black and white, colour keying would do the same as using modes. But the gif file has the center opaque but the outside transparent. So if I were to colour key, the inside would become transparent as well.
  • Mitch Lawrence
    June 27, 2009 at 4:52 pm
    Why not just go to Effects>Keying>Color Key and then use the eye dropper to key out the color you want to be transparent?
  • Iwona Przebindowska
    December 25, 2010 at 8:57 pm
    Great! Thanks! ^_^ I needed it!
