Activity Forums Adobe Premiere Pro Transparency settings
  • Transparency settings
    Posted by Stuart Samuels on November 18, 2010 at 3:16 pm
    Hi.
    I was wondering if there was any way to change a clip’s transparency settings to achieve a similar effect to how different layers transparencies interact with each other in photoshop etc? If that makes sense??
    I can do this in after effects but I’d like to know if there was a way to do this in Premiere at all.
    I’m basically looking for an option to change the transparency of a clip to Overlay, mulitply, screen etc.
    Im using SC3 by the way.
    Thanks in advance!
    Stuart.
    Tim Kolb replied 15 years, 9 months ago 3 Members · 3 Replies
  • Jeff Pulera
    November 18, 2010 at 4:07 pm
    Hi Stuart,
    Can’t speak for CS3, but in CS5, select your clip on the timeline, then go to Effects Controls and open up the Opacity settings – there is an option for Blend Mode and the drop down has about 25 different options, maybe CS3 is the same?
    Jeff Pulera
    Safe Harbor Computers
  • Stuart Samuels
    November 19, 2010 at 1:38 pm
    Unfortunately its not there in CS3. Looks like it wasnt included until later down the line. Maybe I can convince work to upgrade their software now!
    Thanks for your help.
    Stuart.
  • Tim Kolb
    November 21, 2010 at 3:25 am
    What you want is an effect called “calculations” in CS3.
    PS transfer modes are in there.
    TimK,
    Director, Consultant
    Kolb Productions,
