Activity › Forums › Maxon Cinema 4D › Transparency issues…
  • Mark Oertig
    July 20, 2011 at 7:52 pm
    can you maybe upload a small version of the scene?
  • Dean Chapman
    August 4, 2011 at 7:29 pm
    Hey Mark,
    I know this is kinda late….but i still can’t figure this thing out.
    I am super confused as to how the refraction, ray depth, and reflection is working with one another.
    Attached is my scene file…
    2737_refractiontest.zip
  • Brian Jones
    August 4, 2011 at 7:41 pm
    in the three Compositing tags on the walls uncheck Seen By Refraction
  • Dean Chapman
    August 4, 2011 at 8:50 pm
    Hmm, i try that and this is what i get (ive attached a pic)
    On a side note, i accidently uploaded my scene file with “seen by refraction” unchecked for all the planes with the images. So, I made sure to recheck that.
  • Mark Oertig
    August 13, 2011 at 9:08 pm
    Hi Dean
    Like Brian said i switched off the seen by refraction from the 3 wall tags. (seen by transparency on, seen by reflection off) I throwed out all the other Compositing Tags and it looks fine for me. I attatched the file. (R12)
    Or should the Walls also be reflected on the floor?
    Cheers
    Mark
  • Mark Oertig
    August 14, 2011 at 10:59 am
  • Dean Chapman
    August 17, 2011 at 1:45 am
    Thanks Mark,
    Argh…..when i open your file and simply hit the render button, this is what i get (see attached photos).
    I also took a snapshot of my render settings.
    Thanks again,
    Dean
  • Mark Oertig
    August 17, 2011 at 7:50 am
    Hi Dean
    hmmm…thats wierd. When i render it, it looks like that (see link).
    Rendersettings are the same. (does it eventually work, if you copy all the objects into a new scene?)
    Is there maybe a problem with the versionnumber or the system? I’m running R12.048 (Build RC42839) on Windows7 Ultimate 64bit.
    Seems to be a Bug. Can someone else confirm that?
    Maybe ask Maxon.
    Gruss
    Mark
Page 2 of 2
