Activity › Forums › Adobe Illustrator › Transparency issue
  • Transparency issue
    Posted by Benjamin Tubb on March 15, 2006 at 5:30 am
    Hey. I’m very new to Illustrator CS2, but I am fairly experienced with Photoshop CS2. I’m trying to do a live trace on an image of a sailboat that I have. On the image you see the boat, and around it, in between the rigging, etc, there is transparency. But when I do the live trace (starting with ‘photo low fidelity’), it gives me a great big ugly white square around the image. It seems to me (I could be very wrong) that livetrace doesn’t like transparency. That would all be fine, but I can’t figure out how to get rid of the white afterwards… It’s not simple like in photoshop where you just click with the magic wand and press delete. I NEED that alpha in there. Anyone know how I can fix this problem?
    Ben
    Isotrope replied 20 years, 6 months ago 2 Members · 1 Reply
  • Isotrope
    March 24, 2006 at 9:10 pm
    Hi Ben,
    Once you’re satisfied with the Trace, hit Expand in the top toolbar.
    Now select the white part with the WhiteArrow Selection tool (I’m sorry, I forget the official term), hit Delete and you should be good to go. I tend to add a completely different colored rectangle underneath to make it easy to see if my deletion worked well.
    If ever you’ve deleted “too much”, you might have to use the Pathfinder palette a bit (Minus Back) to get it right.
    Hope this helps.
    Cheers,
    iso
