Activity › Forums › Adobe After Effects › Transparency in After Effects?
Posted by Austin Ray on October 27, 2005 at 1:01 pmI
Dan Blaim replied 20 years, 11 months ago 3 Members · 2 Replies -
Steve Roberts
October 27, 2005 at 3:14 pmSince you didn’t mention which effects are giving you trouble I’ll take a stab at it: apply effect>image control>grow bounds above the troublesome effect in the effects stack and adjust its settings until the effect grows.
Other than that, we’d need specifics.
Steve
Dan Blaim
October 27, 2005 at 5:02 pmYou may want to try pre-composing your text layer.
Select your text layer and goto layer menu. Select pre-compose.
be sure to remove the effect that is causing the problem first.
Selecting move all attributes will keep all keyframable actions with the original file.This will create a new composition that is the same size as the original composition.
and the original text layer is now a composition.Now all effects will be bounded by the edges of the composition not the text itself.
