Activity Forums Adobe After Effects Transparency
  • Mark
    October 20, 2008 at 2:38 pm
    In the render queue you need to render out the alpha channel (RGB+Alpha) if you want the transparnecy to show up in rendered movies…you also need to render out to a CODEC that supports alpha channels.
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • David Bogie
    October 20, 2008 at 3:01 pm
    [Gully Moore] “Is there a box in after effects i’m not ticking or something? “
    See the manual for “Interpret footage.”
    bogiesan
