Activity Forums Adobe After Effects Transparency
  • Transparency
    Posted by Dolver on April 30, 2007 at 9:48 pm
    Hey,
    I have created a signature in after effects and I need to import it into flash. My problem is that I can’t seem to find settings that will let me retain the transparency. When I export, I do it to a quicktime file, using the animation codec. Then I make sure to choose lossless w/ alpha, as well as changing all other settings that I can to “w/ alpha” and keep it unmatted. Should I be doing something different? Is there some specific way I need to import the file in flash?
    Thanks for the help.
    Dave
    Andrew Kramer replied 19 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    April 30, 2007 at 9:53 pm
    i think your after effects settings are good for creating transparency… i’m not sure how flash interprets the alpha channel… you could try a png image sequence, i’ve had good results with pngs and software that doesn’t interpret alpha channels.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Andrew Kramer
    April 30, 2007 at 11:02 pm
    Use the export movie function and select flash FLV. In the settings there is an option to retain alpha. Make sure you use a background color in your comp similar to the bg of your flash movie.
    Good Luck,
    Andrew Kramer
    https://www.videocopilot.net
