Activity › Forums › Adobe After Effects › Translating masks from low to high resolution art.
  • Translating masks from low to high resolution art.
    Posted by Jason Hata on October 22, 2015 at 4:43 am
    Hi there, I would say I’m pretty seasoned with After Effects, but I’m sure I missed some basics here and there.
    So I’m working on a personal project just for kicks, where I grabbed some artwork off the web that I liked and wanted to add settle animation for a 10 second loop. I spent quite a bit of time masking out pieces and started animating already.
    I later discovered that there was a much larger sized version of that artwork. A difference between the low quailty 1024×1501 and the larger art at 3475×5093. Is there a way to preserve all the masking work that I’ve done or would I basically need to rework all of the masks that I created to fit the larger art? Once a mask is created, is there a way to just scale the mask itself?
    Thanks very much in advance!
    Kalleheikki Kannisto replied 10 years, 11 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    October 22, 2015 at 6:22 am
    Are the mask paths animated? If not, you can simply select them all and scale (free transform).
    If they are animated, you could probably use the low-res layer as a track matte for the high res layer.
