Activity Forums Adobe After Effects Translate FCP 3 Way Color Corrector in AE
  • Translate FCP 3 Way Color Corrector in AE
    Posted by Andrew Schuurmann on January 23, 2007 at 6:59 pm
    I have a FCP sequence with color corrected footage (using 3 Way Color Corrector filter) that I imported into AE (using Automatic Duck Pro Import). The color correction didn’t transfer into AE, which I expected. The question is, is there an easy way to get the footage in AE to match the color correction I used in FCP? Or is there a way to get the 3 Way Color Corrector filter to show up in AE? The only workaround I can think of is to export the entire rendered sequence as a reference movie, but that doesn’t get me what I need in AE because I need the handles on the media to do transitions with, and there is some masking and sizing I did in FCP that I’d like to be able to manipulate in AE. I also can’t add the correction later in the process (for example, once I’m done in AE I reimport to FCP and then apply the CC filter) because some of the effects I’m planning won’t look right.
    I know there are lots of ways to tweak color in AE but I’m trying to figure out how to translate the values in FCP’s 3 Way Color Correction filter into one or more AE effects.
    Hopefully this makes sense and I appreciate any thoughts on how to solve this.
    Andrew
    FCP 5.1.2, AE 7.0.1
    Sam Moulton replied 19 years, 7 months ago 5 Members · 5 Replies
  • Mylenium
    January 23, 2007 at 7:06 pm
    No. Since AE does not have a built-in 3CC, there can be no effect equivalent. Your best bet is to buy Magic Bullet Colorista, write down the values in FCP’s 3CC and re-create them in AE using said plugin.
    Mylenium
    [Pour Myl
  • Iancorey
    January 23, 2007 at 8:21 pm
    After appreciating the 3CC in FCP and using it a great deal, I actually now prefer to use AEs color correction tools to color correct. More steps, but more control.
    A lot like PhoSho without all the destructive editing.
  • Jimmy Brunger
    January 24, 2007 at 1:50 pm
    Doesn’t Color Finesse come bundled with AE 7.0? I got it included in the goodies folder of my Production Studio Premium discs..Haven’t used it yet, but I’m pretty sure that uses 3 colours wheels… CF is a separate app that opens from within AE though, so I’m not sure how automated it will be. Might need a bit of fiddling.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
  • Andrew Schuurmann
    January 24, 2007 at 8:25 pm
    Yes, Color Finesse was my answer… the interface is a little different, and I couldn’t really get the FCP values to translate exactly, but I managed to get the look about the same.
    Thanks for your thoughts.
    Andrew
  • Sam Moulton
    January 24, 2007 at 11:08 pm
    take a look at this freebie from the DV rebel book. It’s an amazing CC preset from Stu
    https://prolost.blogspot.com/2006/10/rebel-cc.html
