Activity Forums Adobe Premiere Pro Transitions – weirdness
  • Transitions – weirdness
    Posted by Perry Cheng on May 8, 2006 at 10:28 pm
    I have this problem in PPro 1.5 for a while, never gets around to knowing the reason… can someone share some insight?
    Some clips do not allow cross fade transition? I can drag it to one clip end but it does not extend to the next clip? I can drag it to the beginning of the next clip but it does not extend to the prior clip? WHY? Does the clips have to be with the same property? ie picture to picture, video to video?
    Perry
    Perry Cheng replied 20 years, 3 months ago 2 Members · 2 Replies
  • Chris Knight
    May 9, 2006 at 3:44 am
    It means you simply don’t have enough extra frames on the end of the first clip, and/or beginning of the 2nd clip (depending on which clip is giving you the issue)
    Your IN and OUT points are placed too close to the front and end of a captured clip. Next time, capture with handles (extra footage, or “heads and tails”), and you won’t have this problem.
  • Perry Cheng
    May 9, 2006 at 2:59 pm
    I was not aware of there was an option for “captures with handles”. I will check it out. But it happens always with Video+Pictures combo. Video and Pics have long long duration each… Thanks again.
    BTW, with handles, would that increase the size of the file?
    PErry
