Transitions question from FCP to Avid switcher
First I preface this by saying I’ve watched all the tutorials — and it seems the only way to make a glow, blur or other non standard transition in AVID is to overlap two video tracks – create add edit points – then apply the blur, glow etc to each track and play with the opacity to simulate what you can do with ONE CLICK in FCP.
Surely there is a better way. FCP Legacy (not X ..that’s why I’m switching) has a deep independent developer set of transitions and filters. Want a blur – break apart – particle implosion – lens flare transition – drag and drop between two clips and you are done.
AVID has BCC …and then a group of non-searchable filters and transitions – but few that work right out of the box between two clips.
Is there no other way to do the blur, glow – break apart etc transitions other than manipulating filters?
This seems like a serious shortcoming…or …and more likely …just my ignorance here. Thanks for your help –
