Activity Forums Apple Final Cut Pro Transitions outside of primary storyline
  • Noah Kadner
    July 14, 2011 at 8:30 pm
    Yep- that’s how you get transitions off the primary. Don’t forget you can use the compositing fader handles if you only want standard dissolves. But the rest of the transitions require secondary storylines in order to be allowed off the primary storyline.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
  • Simon Ubsdell
    July 14, 2011 at 8:39 pm
    [Thom Stylinski] “I have several images I want to layer on top of each other, with transitions. Is putting each image inside a storyline really the only way to accomplish this?”
    Hi Thom
    Do check out my Adjustable Frame Effect posted here today as it looks like it’s perfect for the job you are trying to do. If you’d like I could make you a version with built-in controllable fades if that would help.
    But yes, the lack of transitions other than in storylines is a major weakness in FCPX at the moment 🙁
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
