Activity Forums Apple Final Cut Pro Transitions on 10.3.3 in 4K
  • Transitions on 10.3.3 in 4K
    Posted by Carlo Ferraro on May 1, 2017 at 12:18 am
    Trying to produce Video Decor samples in 4K and the old dependable Control-T shortcut does not work, sends the very same message:
    “There is not enough extra media beyond clip edges to create the transition”
    but does nothing pressing click, tried to apply ANY transition and it comes out with the same warn.
    Is there a new trick for that simple action?
    Ethan Becker replied 9 years, 2 months ago 3 Members · 4 Replies
  • Bret Williams
    May 1, 2017 at 11:35 am
    Did you trim off the ends of your clips so that there is clip media beyond the edges?
    _______________________________________________________________________
    https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
  • Carlo Ferraro
    May 1, 2017 at 8:29 pm
    Of course I did when it didn’t automatically as usua….
  • Ethan Becker
    July 25, 2017 at 1:15 am
    I have the same problem. anyone have a fix for this? I’ve tried all I know. Yes, I’ve trimmed the ends of the clips. It’s strange. I also tried opening a new project, trimming 2 clips, dragging them both into the timeline, they are both in the primary storyline. When I drag a transition, I get teh same message about “There is not enough extra media beyond clip edges to create the transition.”
    If I trim the clips, no luck. If I let it trim the clips, no luck. I’ve tried most of the transitions with the same results.
    Anyone have ideas on how to fix this? It’s strange. In the past, I was able to be able to work around it with something like “Black Hole” and then once it worked, I could change it to dissolve. But, there has to be a better way.
    Ethan-
  • Ethan Becker
    July 25, 2017 at 1:45 am
    Hi Everyone,
    I followed these instructions to remove FCPX
    https://support.apple.com/en-us/HT202412
    Then I reinstalled from the App Store, and openned my library… Bam… Works as advertised… Something must have become corrupted.
    I hope this helps someone else
    Best,
    Ethan-
