Activity Forums VEGAS Pro Transitions cover widescreen bars problem
  • Transitions cover widescreen bars problem
    Posted by Jeremiah Fox on June 3, 2012 at 6:34 am
    I added widescreen bars to the image, but when I add a cross disolve or make a transition it covers the entire widescreen bars and image. How can I made it transition on just the image and leave the widescreen bars alone?
    Mike Kujbida replied 14 years, 2 months ago 5 Members · 11 Replies
  • 11 Replies
  • Steve Rhoden
    June 3, 2012 at 11:41 am
    If its a filter/plugin you use to make your widescreen bars, drop
    it instead on the entire video track itself, instead of the video
    clips. Or drag it unto the preview window which would
    make it cover all the tracks.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • John Rofrano
    June 3, 2012 at 1:13 pm
    The question is why are you making Widescreen Bars? There is no need to ever do this. If your content is widescreen but you need to deliver it in standard 4:3 ratio, you do this at rendering time, not editing time. That’s your problem.
    Change your project to widescreen and render to 4:3 and let Vegas add the widescreen bars for you. Then none of the transitions will ever have a chance to mess this up.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    June 3, 2012 at 2:58 pm
    Are you trying to get a curtain effect like a movie in a screen?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jeremiah Fox
    June 4, 2012 at 5:46 am
    Yes, I am adding widescreen as a effect for a music video. I change the various widescreen looks through out the video for spectacle. I also improve the compositions, because when I add the widescreen bars , I can adjust the image up or down to get a more cinematic look. Its a needed effect for my stuff. Im having trouble here.
  • Steve Rhoden
    June 4, 2012 at 10:47 am
    What kinda of trouble are you still having?
    Havent you read or tried any of the recommendations you were given?
    However, you are still not fully and clearly explaining your workflow.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • John Rofrano
    June 4, 2012 at 10:53 am
    [Jeremiah Fox] ” I am adding widescreen as a effect for a music video. I change the various widescreen looks through out the video for spectacle. “
    Then you need to add the widescreen bars on a separate track so that they are not affected by any transitions. You can just use generated media to do this or make them in Photoshop and place them on a higher track.
    ~jr
  • Jeremiah Fox
    June 15, 2012 at 4:53 am
    Thanks for all the advice. I have premade widescreen bars I added on a higher track. The transitions work great. One other problem is now occurring. When I burn a DVD, there is a light white line where the actual footage widescreen bar ends which is in the middle of my pre made bars. Any idea what this is?
  • Jeremiah Fox
    June 15, 2012 at 5:02 am
    Here is how it looks.
  • Mike Kujbida
    June 15, 2012 at 9:12 am
    [Jeremiah Fox] “Here is how it looks.”
    No picture to look at 🙁
  • Jeremiah Fox
    June 15, 2012 at 11:31 pm
    Unfortunately, I am unable to upload the image. It does not load in the upload box, however its just a light white line across the bars I pre made and added. Does anyone have any idea what can be done for this?
